CHKDSK i njegove tajne
Post 02 Dec 2017, 06:52
Dakle, obavila sam sam to na prve dvije particije (C i D) - ostao mi je još E, ali to je malo, neke četiri gige, mislim, i ne vjerujem da ima veze s mojim problemima.
Evo rezultata. Kopiram samo ono što je relevantno, prolog i epilog znate kako glasi.
Checking file system on C:
Cleaning up instance tags for file 0x11f11.
Cleaning up minor inconsistencies on the drive.
Cleaning up 3584 unused index entries from index $SII of file 0x9.
Cleaning up 3584 unused index entries from index $SDH of file 0x9.
Cleaning up 3584 unused security descriptors.
CHKDSK is verifying file data (stage 4 of 5)...
Read failure with status 0xc000009c at offset 0xef9df000 for 0x10000 bytes.
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
Free space verification is complete.
Windows has made corrections to the file system.
51199123 KB total disk space.
26221124 KB in 112900 files.
73912 KB in 10147 indexes.
0 KB in bad sectors.
272899 KB in use by the system.
65536 KB occupied by the log file.
24631188 KB available on disk.
4096 bytes in each allocation unit.
12799780 total allocation units on disk.
6157797 allocation units available on disk.
Internal Info:
e0 93 02 00 b2 e0 01 00 2c c1 02 00 00 00 00 00 ........,.......
7d 01 00 00 09 00 00 00 68 12 00 00 00 00 00 00 }.......h.......
2c 11 3b 1e 00 00 00 00 8a 40 43 65 00 00 00 00 ,.;......@Ce....
5a 12 86 85 00 00 00 00 e4 d0 9e db 11 00 00 00 Z...............
7c 23 22 ed 00 00 00 00 7e 7c 10 e6 13 00 00 00 |#".....~|......
90 30 af c6 00 00 00 00 b0 3a 07 00 04 b9 01 00 .0.......:......
00 00 00 00 00 10 69 40 06 00 00 00 a3 27 00 00 ......i@.....'..
Checking file system on D:
Cleaning up 24 unused index entries from index $SII of file 0x9.
Cleaning up 24 unused index entries from index $SDH of file 0x9.
Cleaning up 24 unused security descriptors.
Read failure with status 0xc000009c at offset 0x6300515000 for 0x10000 bytes.
432132400 KB total disk space.
404353132 KB in 333755 files.
116488 KB in 18246 indexes.
493240 KB in use by the system.
127020 KB occupied by the log file.
27169540 KB available on disk.
108033100 total allocation units on disk.
6792385 allocation units available on disk.
Internal Info:
30 61 05 00 0c 5f 05 00 5a 0a 08 00 00 00 00 00 0a..._..Z.......
39 2e 00 00 00 00 00 00 34 00 00 00 00 00 00 00 9.......4.......
9a 77 e9 3b 00 00 00 00 8e ce af 24 01 00 00 00 .w.;.......$....
62 35 2f 3e 00 00 00 00 2e 90 96 fb f4 00 00 00 b5/>............
ec 0d e9 99 00 00 00 00 c2 5d de 54 f7 00 00 00 .........].T....
a0 57 af c6 00 00 00 00 b0 3a 07 00 bb 17 05 00 .W.......:......
00 00 00 00 00 b0 c1 67 60 00 00 00 46 47 00 00 .......g`...FG..
Ove brojke i slova na kraju svakog izvještaja nisu mi jasni, naravno, ali bi li ovo značilo da je CHKDSK sredio bad sectors ili ne? Ako da, zašto i dalje prijavljuje grešku. Doduše na SCM-u, ali svejedno?
Bi li netko bio tako ljubazan da me prosvijetli?
Zmaj021
Been thanked: 11 times
Post 02 Dec 2017, 06:56
opusti se, sve je u redu.. :D
Post 02 Dec 2017, 07:30
Lako je tebi govoriti, a to što ja već tjedan dana svako jutro provjeravam Event Viewer i svakih pet minuta fajl na kojem trenutačno radim prebacujem na vanjski disk, to ništa? :D
Nego, taj vanjski disk ponaša se kao dvostruka ličnost. S jedne strane funkcionira kao vanjska memorija - znaš, ono 'safely remove' - a s druge, ako obrišem fajl, pošalje ga u Recycle Bin, a ne ubije ga zauvijek. :misli:
Zmaj021
Post 02 Dec 2017, 08:25
mora safely remove.. radi integriteta podataka. recikliranje nije loša stvar. pošto je hdd, onda pravi svoj rb. valjda. :D
s vremena na vrijeme ga isprazni i to je to. ono, ako ti manjka prostora.
..sumnjam da te brine mogućnost reciklaže kompromitujućih fajlova. :D
Post 02 Dec 2017, 08:57
Ne brine me, dakako. Samo mi je čudno što se tako shizofreno ponaša. Prostora ima, to nije problem, ali nisam sigurna da ima svoj RB. Morat ću se s time poigrati.
Jebote, na što ja gubim vrijeme... :facepalm:
Has thanked: 918 times
Been thanked: 1762 times
Post 02 Dec 2017, 09:57
S particijama je sve u redu, barem prema 'logovima' koje si dobila nakon skeniranja. Provjeri drajvere za hard-disk.
Post 02 Dec 2017, 11:18
Kaže: This device is working properly. Pod driver file details stoji: C:\windows\system32\drivers\disk.sys i C:\windows\system32\drivers\part.mgr.sys. Treba li još štogod? :ne zna:
Post 03 Dec 2017, 16:26
Nemam pojma. Koji je to OS? Windows XP?
Post 03 Dec 2017, 17:23
Stitch wrote: ↑
03 Dec 2017, 16:26
Kako nemaš pojma, a dijeliš mi savjete? :D Da, XP.
Hoćeš i log za E particiju? :raspa:
Post 03 Dec 2017, 17:40
Ne treba. Drajveri bi standardni trebali biti, nijedan hard-disk ne zahtijeva posebne programe. Ali da se sjećam koji je softver posrijedi... :rolleyes:
Tko ti je kriv što imaš pretpotopni OS. :zubeki:
Post 03 Dec 2017, 17:50
Na drugu loptu: jesi li pomicala kućište? Tresla ga na bilo koji način?
Otvori ga i provjeri spojeve. Prašina i utori, te dvije stvari često uzrokuju probleme. Odspoji podatkovni i kabel od napajanja, uzmi sprej s komprimiranim zrakom i "propuši" sumnjiva mjesta.
Post 03 Dec 2017, 18:49
Ne komplicirajmo. Mali me zajebava, a ima već i koju godinicu. I ne maši mi tu s novim OS-ovima. :D
Kompjuter ima svoj ormarić, ali jasno je da sve probleme rješavam udarcem gojzericom: u tu ga svrhu izvadim iz ormarića, dobro nalupam, odspojim sve kablove, ispušem ga usisavačem pa može biti da je to.
Inače, ispuhivan je relativno nedavno, kada mi je grom ubio mrežnu karticu. :crying:
Idem sad. Veza mi je očajno spora, a tako mi i treba: lijepo su mi nudili bržu varijantu za samo dodatnih 10 kn mjesečno, a ja sam rekla da mi ne treba. Tko je onda znao da ću skidati filmove s neta. :facepalm:
    Users browsing this forum: ClaudeBot, Reflectionbot and 3 guests
